Watercooling pcv300
  • Thread starter Thread starter 4p
  • Start date Start date
4p
4p
20 Jun 2006
Capital of The North
Externally.
At the back of the case i have two 40mm spaces for 2 extra fans.
Now, if i removed the Grill so to speak i would have 2 nifty holes for pipes to go in and out.
hmmm?
The reason i ask is because a decent cooler for the cpu ends up being too big for the case.
It would work, as would a Koolance setup.
You can also internally watercool if you like, there is enough room.
oooo
cheers
I got mine watercooled internally too.
Just had to hack away the 5,25"and 3,5" drive cage to put the dual 120mm radiator in.
Too bad the P5B-VM from Asus is crap atm.
Using Scythe 21.something dba fans. Very quiet.
