Hello, I recently installed about 5 days ago the following spec into my rig:
CPU - Swiftech Apogee
GPU - Dangerden Maze4
Thermochill PA120.2 with two Nexus fans at 12v
Dangerden D5 Pump
However I am concerned about the performance, as i am hitting anything upto 46 degrees on the CPU when gaming from an idle of about 35 degrees. The GPU never goes above 40, i have tried reseating the Apogee but this didnt make any difference. I have also just run my hand under the bottom inlet of the cpu block, to find a small bit of water clinging onto it. Could this be a source of the performance deficit, and can anything be done to stop the leak, i have tightened it up but this has only reduced it slightly, maybe a possible RMA? Also am i expecting too much cooling capacity from what i have bought?
My Spec:
3500+ Newcastle
x800xt
Both running at stock for now
Thank you
Alex
Dangerden D5 Pump
My Spec:
3500+ Newcastle
x800xt
Thank you
Alex
