Hi Guys,
Going to move to watr cooling to queiten down the system, will be using a cpu, gpu and chipset blocks and a single rad with 120mm fan.
Hoping to mount the rad in the top of the case with the fan blowing air up through it out of the caes(is it better to have it blow through or suck through?)
I have a 120mm fan in the power supply chucking air out the back.
Is there anything else I would need? some sort of air intake fan?
I have a mounting for a fan on the side of the case and one at the front should I add anything to these? any other components I should consider cooling?
Going for silence rather than o/c.
Rig is as my sig
Rig is as my sig
