- 4 Apr 2006
- Norwich
hi all.
i currently have the thermaltake big water bay mounted jobbie.
needless to say i havent found the cooling to be amazing.
what im wondering is, is the lack of cooling power due to the small radiator unit.
if so, could i get a seperate rad, and tube it into the loop to give extra cooling?
this then opens further questions, is the pump in this unit strong enough to be used with a seperate rad as well?
and if it is, where in the loop should i add the radiator? with it being a pre made unit i seem to be left with the choice of, after the pump and before the water block or after the water block but the before the rez, rad, pump of the unit?
any adivse on the above would be greatly appreciated
Loki
Loki
