WATERCOOLING PRICE DROPS
11 Dec 2005
Cheshire
The OcUK Watercooling range has had massive price cuts. Here are a few of the best offers.
EK HD 5870 Acetal Full Cover VGA Water Block @ £64.81 inc VAT
The well-established manufacturer EK-Waterblocks has again designed and manufactured a waterblock of excellent quality, this time for the HD5870 graphics card. The beautifully machined copper waterblock with an Acetal cover features many finely crafted features such as the complex baseplate design or the engraved logo on the cover. The waterblocks can be mounted with the included M3 screws.
The cooling design itself with its wide channels ensures high flow rates. The integrated VRM cooler completes the package and ensures that every important component on the card stays cool. This allows stable operation even at the highest summer temperatures, a maximized overclocking potential as well as low noise all at once.
The waterblocks is designed for the highest quality requirements. The copper baseplate is perfectly plane and polished, the seal between top and copper is achieved with a durable and specially fitted gasket.
This card is compatible with all 5870 graphics cards in reference design.
- Dimensions of copper base: 165 x 119,5 x 8mm
- Dimensions of acrylic top: 165 x 119,5 x 8mm
- Threads: 4 x G 1/4
Only £64.81 inc VAT.
ORDER NOW
Silentstar Single Core Rev 2.0 Hard Drive Cooler @ £21.96 inc VAT
The SILENTstar HD-Core coolers decouple and cool 3,5" HDDs. The cooling profiles are identical to the box-versions, additionally attachable decoupling elements are included. The hard drives are screwed between the cooling plates and mounted vibration-less with the decoupling modules in the case. An optionally available bottom plate also cools the HDDs underside.
- Material: Copper, stainless steel, POM
- Dimensions: (LxWxH) 170 x 30 x 16mm
- Weight: 400g
- Connectors: G1/4" threads
- Compatible to: 1x 3,5" SATA HDD
Only £21.96 inc VAT.
ORDER NOW
Phobya DC12-400 18W 12Volt Pump @ £29.41 inc VAT
After the first products the manufacturer consortium Phobya now introduces a pump series which rattles the cages in the performance-pump sector. This product perfectly combines all the requirements from different watercooling users:
Quiet: At less than 25dB even most fans in the system emit more noise. For decoupling and therefore further noise reduction two kits are included with the pump: The first a map for quick and easy mounting on the case floor. The mat is self-adhesive on both sides and therefore reliably fixates the pump. The second possibility for pump installation are two brackets with which the pump can be fixated in the case.
A ceramic-based centrifugal bearing promises quiet operation and a long lifespan.
Compact: With the small outer dimensions (see technical specifications) the pump can be installed in almost any corner of the case, even in Midi- or Mini-towers. The compact dimensions of the pump also make connection to the cooling loop easy as the pump's position can easily be varied.
Powerful: Such a small and quiet pump so far always required compromises regarding the power. Not anymore! 4m of pressure head and 800l/h of flow are the kind of performance that will not be stopped even by cooling loops even with multiple waterblocks.
G1/4" connection: No adaptors, no annoyingly long connectors any more! Simply screw in the desired connector and you are set to go!
12V connector: The first advantage of a 12V connector is that it makes the connection with a 230V cable obsolete and that internal operation is made safe and easy. The other great feature of this pump is the connector: It is not a standard 4-Pin Molex connector, it is a 3-Pin fan connector which powers this pump (Important: Check the requirements and capabilities of the sockets to which you connect the pump). This pump can therefore be operated at a fan connector on a Mainboard or a fan controller. This also allows a speed reduction of the pump: Only 8V are required for starting and operation of the pump which makes it additionally quiet and smooth in operation. The fan connector also offers the advantage of rpm monitoring with a compatible controller.
Technical specifications:
Color: Black
Casing material: Plastic
Outer dimensions: (L x W x H): 75 x 66 x 54mm
Connection thread size: G1/4"
Power connector: 3-Pin
Nominal operating voltage: DC 12V
Starting voltage: DC 8V
Power consumption: 18W
Current draw: 1.8A
Max. pressure head: 4m
Flow rate: 800 l/h
Lifespan: 50.000hrs
Noise emission: below 25 db
Extent of delivery:
1x Pump
Decoupling mat
Decoupling bracket with 2x 4mm holes
Only £29.41 inc VAT.
ORDER NOW
Swiftech MCP350 10W 12V DC Pump @ £44.67 inc VAT
As the computer industry continues to accelerates its pace towards implementing liquid cooling solutions, pumps have become a pivotal concern for the adoption of such systems in mission critical machines. Small size, low or no maintenance, similar to that afforded by fans, and extended reliability are prerequisites for the successful transition from air to liquid cooling systems. Despite a remarkably small footprint of 2.4" square, the MCP350 features an astounding 13ft of head to provide superior flow rates in today's most complex liquid cooled systems. High reliability, high pressure industrial pump, featuring a 50,000 hour MTBF (5 year lifetime). Such reliability is afforded by the unique design of this pump, which contains only one moving part: the magnetically driven rotor/impeller spins on a single ceramic bearing, thus extending the life of this pump beyond existing standards. The pump is completely plug-and-play, and connects directly to any computer power-supply through standard 4 pin power connectors. It's compact design, quiet and powerful motor make it ideally suited for heavy duty cooling in environments where space is at a premium.
- 50,000 hours MTBF (Mean Time Between Failure) equivalent to 5 years lifetime
- Superior 12 Volts DC convenience: plugs into the computer power supply
- Superior real world performance thanks to its high pressure characteristics (13ft of head). Particularly well adapted to the proliferation of daisy-chained liquid cooling devices in a single circuit: Multiple Processors, Chipset, Graphics, and Hard Drives.
- Compact Design.
- Quiet Operation thanks to brushless motor. 24 to 26 dBA
- 3/8" barb fittings.
- No maintenance when used with de-mineralized water, and anti-fungal additives
- RPM sensor plugs to 3 pin motherboard fan connectors and reports impeller rotational speed.
Only £44.67 inc VAT.
ORDER NOW
Phobya G-Changer 120.1 120mm Radiator @ £24.44 inc VAT
The choice of material is the basis for any great radiator. Copper fins and brass chambers are the traditional and proven materials for radiators with outstanding performance. The frame construction was coated with a robust layer of high-grade lacquer. The fins are coated with a thinner layer to improve the appearance without compromising cooling performance. The whole radiator is surrounded by a shiny metal frame which gives a great overall appearance to the radiator. The Phobya logo was machined into the sides of the radiator to show that this radiator is a serious heat exchanger.
Based on the right choice of material and design the Phobya engineers have implemented many technologies to achieve outstanding cooling performance. The first idea was that improved flow rates result in improved cooling performance. Therefore the G-Changer series feature parallel double cooling channels to greatly reduce flow resistance of the radiator. Additionally the channels were sub-divided internally to increase the contact surface of the coolant in order to draw as much heat from it as only possible. The fin spacing and size was chosen to work efficiently even with medium-speed and slow fans to achieve the best noise- to performance ratio. The unique design of the fins of this 60mm thick heat exchanger additionally allows great performance increases when using High-powered fans which makes it extremely versatile and perfect for any application!
What good is great performance if the radiator is a pain to install? To make installation quick, easy and safe the engineers at Phobya came up with another innovative concept: The radiator is equipped with connection threads both on the front and bottom which greatly increases the possible mounting locations of this radiator. The two included black thread sealing plugs safely seal the two unused threads shut.
The M3 threads in the sides of the radiator are another new feature which promises greatly eased installation: These threads allow quick and rigid installation of the radiator in 5,25" drive bays. For easy deaeration of the radiator a bleeding screw was integrated at the highest point of the back of the radiator. When filling the system simply open the screw slightly until all air is bled from the radiator. Then screw the cross-slotted screw in again and you are set to go with a completely bled radiator!
The radiator is shipped with decouplers which can be inserted between fan and mounting frame. When the mounting screws are fastened the radiator and fan form a unit which directs Airflow directly onto the fins which ensures the best possible cooling performance.
Material: Copper fins, brass chambers
Dimensions: (L x W x H): 172x125x60mm
Connection threads: G1/4"
Weight: approx. 831g
Mounting threads: On both sides for fans or mounting, on sides for mounting
Mounting thread size: M3
Fan size compatibility: 120mm
Pressure tested: 2 Bar
Other features: Bleeding screw
Extent of delivery:
1x Radiator
4x M3x30mm Screws
1x Decoupler
2x Black Seal plugs
Only £24.44 inc VAT.
ORDER NOW
Bitspower G1/4" Silver Shining Compression Angle Fitting for Tube 10/8MM (BP-WTP-C41 @ £4.69 inc VAT
Bitspower G1/4" Silver Shining Compression Angle Fitting for Tube 10/8MM (BP-WTP-C41)
Only £4.69 inc VAT.
ORDER NOW
Bitspower Premium G1/4" "Stubby" High Flow 7/16" Fitting - Black Sparkle Finish (BP-BSWP-C34) @ £0.99 inc VAT
This is the finest made fittings we have ever offered! This is a replacement barb for any product that use G 1/4" fittings. These will screw into any available port. Learn the name; Bitspower Premium water cooling products!
- Special Design for PC Water Cooling
- Short Stubby Fitting for tight areas
- Perfect Surface treatment
- TRUE Hi-Flow
- Hidden O-Ring Design
- Material : Hi Quality Brass
- Thread : G1/4"
- Thread Length : 5 MM
- Tubing Application : 7/16"
- Tubing Side Length : 9.8 MM
Only £0.99 inc VAT.
ORDER NOW
TFC Compression Fitting G1/4" Thread 3/8" ID/1/2" OD - High Flow @ £1.07 inc VAT
Fitting large bore tube just got easier with the TFC Compression Fittings! 1/4" BSPP (G1/4") Thread to 3/8" ID - 1/2" OD hose fitting that will fit all tubing which has a 3/8" ID and 1/2" OD (1/8" Walls).
Only £1.07 inc VAT.
ORDER NOW
EK Reservoir for Phobya DC12-400 / EK DCP 4.0 @ £23.64 inc VAT
This reservoir's concept is based on the classical EK Water Blocks RES reservoirs. A great advantage of this reservoir in combination with these pumps is that it can be installed in any position in the case, be it upside down or on their side, the pump can still run at full power. The inlet can be chosen between the middle or lower thread at the front of the reservoir. The unused thread can be sealed with the included seal cap or e.g. a lighting module with a LED which are also available at our webshop. This allows even more modding effects which make your system a truly unique piece of art.
Compatible, amongst others, with the Phobya DC12-400 pumps.
Material: POM (End pieces), Plexi (Tube)
Thread size: G1/4"
Extent of delivery:
1x EK Water Blocks EK-Reservoir for Phobya DC12-400 / EK DCP 4.0
1x Sealing plug
Only £23.64 inc VAT.
ORDER NOW
Heatkiller CPU Waterblock Revision 3 LT (Socket LGA1156) @ £34.50 inc VAT
The HEATKILLER® CPU Rev3.0 LT sets a new benchmark in cooling performance, build quality and user friendliness. The waterblock was designed with the newest CPU generations in mind.
Central flow design, paired with a sophisticated nozzle plate and an extremely fine cooling geometry give the waterblock outstanding cooling performance while still having a very low flow resistance. The baseplate can geometrically adapt itself to the CPU. When used on a Quad Core CPU a distributor plate is included which directs the flow of coolant parallel to both DIEs of the CPU.
The modular design allows easy opening of the HEATKILLER®, the change of the mounting plate to allow installation on another socket is done easily and quickly. Separately available mounting plates and replacement parts ensure, even after years, perfect operation and performance.
The cooling geometry is made from electrolyte copper, the cover is made from high-quality POM. The mounting plate and design applications are made from stainless steel.
- Material: Electrolyte copper, POM, stainless steel
- Dimensions (block): 59 x 59 x 17,5mm
- Weight: approx. 150g
- Pressure tested: 5 bar
- Seal: EPDM 75 (max. 150°C)
- Thread size: G1/4" (DIN ISO 228-1)
- Compatible with Intel socket 1156
Only £34.50 inc VAT.
ORDER NOW
