Watercooling project
25 Jul 2006
Taunton
Sat here tonight at this time in the morning a wave of inspiration hit me to completely watercool my Nine Hundred Gaming case that is just sat under my desk unused at the moment.
recent talks with Raikiri have really got me thinking about a dual loop setup which without a doubt would be awesome, even with the hassle. So i wondered to myself... "how would i do it?" and a few ideas started popping into my head and the main one was to mount a rad facing into my case at the back, like i was planning on my 1st attempt but didnt succeed because the drill bits were pants, so i will buy new drill bits and make sure that happens this time. i will then have one at the front mounted to one of the front fans behind the grill. the one at the front doing gfx and the one at the back doing cpu and possibly chipset. i was thinking of getting two bay res's so that water levels were easily attainable and hopefully not too hard to top up.
then i got round to pumps and thats where im stuck, i need two decent cheapish pumps, identical if possible, one to power each loop. i expect both to have to be positioned on the bottom of the case so they will have to be fairly powerful, so ideas for these would be appreciated.
i also need to find another cheap rad. i need another 120.1 which is fairly low profile where the barbs are as my plans mean that the barbs cant stick out too much.
the sort of spec i would be going for over the coming months is something like quad core and 8800GTX/9800GTS, would a single 120.1 be enough to cool a 8800GTX? or would this depend more so on the pump res and block used in conjuction with it?
also what do you think of what i consider "fairly ambishous" project, espically for a Antec Nine Hundred, which i would never ever suggest for watercooling.
i'll try and get a diagram up of how i would like/expect it to look. :D
To be honest i think if you build tidy you could get a 120.2 on the front grill possibly do cpu and chipset or sli and crossfire and then fit a single 120rad to the back or if u remove the weird shapped 200mm fan ontop u could get another rad on top. Thinking about my rig might end up getting another single120mm or rad for now but 1 cooled with fans not passive and use that for cpu and possibly make its own loop on its own pump and leave the reserator just for crossfire.
Just thought id show off my nine hundred water cooled :) which will very soon probbaly be all built in if i can scrape the cash :)hope u like :)
you could cool a quad and sli gtx's on a 120.1 if you wanted, but temps wouldnt be all that great (maybe equaling aircooled).
depends what you want from the system...
Some good info there. The PSU calculator is a bit iffy though. The GTX core puts out 100w of heat according to Swiftech.
A PA120.1 will cool SLI 8800 GTX's at roughly around 45c (dependant on ambient etc...) A PA120.1 in theory could handle a quad, but start overclocking it and things will get toasty.
If you are running things at stock then 2 x PA120.1's will work.
Overclocking...2xPA120.2's.
A Tec on 1 GFX card will need a PA120.3.
The slim line Black Ice Rads may fit better, but performance will suffer.
black ice would do but ** going have to push a hell of a lot of air though it to get same results as a PA120. thats like going back to old delta days, more cfm more noise.
