I’m looking at moving into water cooling; though for a quieter PC as opposed to significantly improving my overclock (in the new year PC will be used more for work as well as gaming). I’m currently running a Core Duo E6700 moderately overclocked to 3.05GHz, without increasing any voltages, using the Freezer 7 Pro. My 8800 GTS 320Mb is a factory overclocked version running at 580MHz/1700MHz.
I’m considering watercooling only my CPU initially, and fitting the Thermalright HR-03-PLUS to my GPU. The reason for this is because I’m looking at upgrading my 8800GTS when the new GeForce 9 series of cards come out in the first part of 2008, and I’ll look into adding that into my loop.
The watercooling parts I’m considering are:
Danger Den DD12V-D5 Pump
XSPC Passive Aluminium Reservoir (fitted externally)
ThermoChill PA120.3 Triple 120mm Radiator (fitted internally at base of case with additional air vents drilled)
D-TEK FuZion Universal CPU Block
Have a few questions:
1. The pump – I know this is a fairly powerful pump, but how noisy is it compared to other pumps? Would anyone suggest a different pump that might give me a better noise/performance balance?
2. Tubing – I understand from what I’ve read that Tygon tubing is the best, but how is it better than Masterkleer?
3. Fittings, etc – I’m looking at a ½” system, so what other fittings do I need? As I’m not using a windowed case, what coolant would you suggest, or isn’t there a lot of difference between them?
4. Overclock – I would like to improve on my current overclock (yes, want my cake and eat it ideally), which I know will require an increase in voltages. I know an increase in voltages=higher temps, so in my air cooled system this would mean more noise from my harder working CPU fan. Will increasing voltages therefore not affect the noise levels on my proposed water cooling setup?
5. Fitting – anyone fitted this ThermalChill radiator into this case? (see below) Does what I propose fit, and is it the best place for it?
PC spec for reference:
Asaka Mirage 62 case (additional Noctua 120mm fans fitted, intake and exhaust)
Corsair HX 620w PSU
Asus P5K P35 motherboard
Intel Core Duo E6700 CPU @ 3.05GHz
Artic Cooling Freezer 7 Pro HSF
2GB OCZ PC2-8500 Reaper HPC DDR2 memory
BFG GeForce 8800 GTS OC2 320Mb GPU
Samsung Spinpoint T166 HD501LJ 500Gb Hard Drive (main)
Maxtor 320Gb Hard Drive (backup)
21” Iiyama Visionmater Pro 501 CRT monitor (HUGE and old, but great quality images)
SteelKeys 6G keyboard
Razer Copperhead mouse
Windows Vista 32-bit Home Premium
Really appreciate all replies, comments, suggestions – thanks in advance!
Corsair HX 620w PSU
