Watercooling queries
17 Dec 2004
UK.
I'm new to WC and am currently planning a new build. I'm going to need to be cooling two 580gtx 3gigs and an i7 2600k.
I was looking at the V12 pre-setup with the Corsair 800D case but I assumed the cooling would cover the CPU and both GFX cards. I can see now that I am going to be needing to add more pressure and cooling to the loop.
I'm guessing a lot of people are cooling a CPU and 2 GFX Cards so could someone maybe post a pic of they're setup or maybe found some clever effective ideas over the years? ;)
Many thanks.
A 480 rad/ 2 x 240 will be ample for our setup.
I'd suggest either calling OcUK to arrange this or buying the bits on their own. plenty of help on here if you do need it :)
I was cooling a pair of 3Gb 580's and an i7 950 with a pair of XSPC RX 120.2 rads and temps were fine so as mentioned above a pair of 240's or a 480 is what u really want to be looking at and try and go for higher quality rads like the RX, Black Ice SR-1 or Thermochill TA.
