I doubt it, the 1800xt chucks out a fair bit of heat, depends on the rest of the equipment but i think it would struggle to get rid of the heat, id say go with a double.BEn_2600+ said:Hi, Would a Single 120mm Rad be able to handle the following:
- E6300 @ 3.4Ghz 1.315v
- X1800XT 256Mb
Thanks a lot, Ben
I'm unsure on that make.BEn_2600+ said:Does anyone know if Flow 120 Rads are any good, seen them for sale very cheap, so just wondering?
Thanks, Ben
Thanks, Ben
BEn_2600+ said:Why is a Dual 120 £2 dearer than a single??? Might aswell get a dual, as 2 singles would be £80oddJust need to work out where i can put it in my V1000 with no/little modification
If i remember right, i think the HEs are discontinued.BEn_2600+ said:How much difference is there between Thermochill HE and PA?
Yeah, pics helped me a lot when i decided to watercool. Take a look at the watercooling case gallery.BEn_2600+ said:Thanks for the pics topgun, I dont know which way ill mount it, the images have helped tho Thanks a lot![]()
topgun06 said:If i remember right, i think the HEs are discontinued.
http://forums.overclockers.co.uk/showthread.php?t=17305236&highlight=watercooling+case
Now i know the true differenceJokester said:The PA is better in every respect compared to the HE. The HE only equals the performance if you're using high flow fans.
How Much difference would i be looking at If I used a HE instead of PA with Sharkoon 1000rpm or Scythe 1200rpm fans?
