I have been looking to get water cooling for when i finally upgrade to Core 2 Duo (Possibly quad) but would like to play about with it on my older system first. Currently i have a socket 939 processor. I would like it to be an fully internal loop but space shouldnt be a problum as i have a Stacker 810 case.
I have been looking around reading a lot and came up with this for a loop:
Radiator: Black Ice GTX240
CPU Block: D-TEK FuZion CPU Block
Pump: Laing DDC- 1 Ultra 18watt Pump
The water flow would go Pump>Radiator>Block>Pump
Questions i have are:
1) What size of tubing is best? 7/16 or 1/2?
2) Is that cpu block any good for use on a quad cpu? or would it be better to wait and see if any better cpu blocks are coming out?
3) Would getting a north bridge block be wroth while?
4) Does it require a lot of maintenance? or just set it up and check it for the first week or so and let it go.
5) Can the case be put on its side for changing components when its full of water? and can it be transported while full of water?
And finally is a 75% tap water to 25% anti freeze ideal to be used?
Any input would be great.
. Even tho its fitting nicely whats a few pounds for some jubilee clips, don't want water all over the inside of your case lol. Seen your thread Pink, good luck drilling and fitting the radiator
