- 22 Dec 2007
- Newcastle
I've got a question as i'm about to delve into watercooling
for the first time, ok i'm a WC noob and i'm going for a kit
a Swiftech H2O-220 Apex Ultra+ exact and while i was looking
through an installation manual i found this
Use of alcohols (Alcohol Allyl, Amyl, Benzyl, Ethyl (Ethanol), Isopropyl, Methyl (Methanol), n-Butyl) or
antifreeze products containing the listed alcohols is prohibited as it will result in deterioration of the
reservoir over-time, and will void your warranty
and this
Use of coloring die or fluorescent additives
containing particulate fillers will cause excessive
wear to the pump’s impeller bearing
so considering i was planning on using some Feser
One UV Reactive Coolant in the lovely Acid Green
colour i'm now however a little bit worried, does it
adversely affect the pump or "melt" the reservoir.
Please help me out and save my bacon
Cheers
and this
Cheers
