ive just bought a corsair 570x, and i have a thermaltake riing 360mm radiator bundle, i also have 3 spare fractal design fans that are 120mm, as far as im aware the case supports a 360mm radiator at the front, and 3 fans come included (2 on the top, 1 at the back).
my first question is what direction do i have the 2 fans on the top? are they suppose to be intake or exhaust? in which way is which for fan direction.
second question is, is it possible to use 6 fans for a 360mm radiator, with 3 on each side? i think ive seen this somewhere and i want to make use of these fractal design fans that i dont use at the moment, and if so which direction do i need the fans? intake or exhaust? also how can i connect 6 fans to my motherboard as a cpu cooler, the thermaltake has a control hub kind of thing but obviously only for 3 fans. thank you
