=== Watercooling Range - New Products & Layout ===
9 Nov 2003
Leeds
Over 500 new Watercooling products now available from the biggest names in the market in a new and easier to use section. Further improvements will be made so make sure you check back regularly! :D
CLICK HERE to view the full range or see some of the brilliant products recently added below:
*** *** XSPC Delta V3 CPU Waterblock (LGA775/LGA1366) @ £37.94 inc VAT *** ***
Building on the X2O Delta V2 block the X2O Delta V3 i7 pushes the performance even further. Whilst being fully compatible with every single socket on the market, this block has been thoroughly re-designed internally to help cope with the latest Dual and Quad core CPU's. The Delta V3 is the ultimate low pressure drop / high performance CPU waterblock.
- New CNC Cut Acetal Top (Version 3)
- Inner Body/Base: New Machined Copper Design
- Inlet/Outlet Ports: G1/4"
- Over 1600 Copper Pins
- Precision cut to 0.4x0.4x4.2mm
- 26mm Stepped Base
- Designed for Dual and Quad core processors
- Universal Mounting Hardware
- All Nuts, Bolts, Springs & Washers
- Silver Thermal Grease
Only £37.94 inc VAT.
ORDER NOW
*** *** Heatkiller CPU Waterblock Revision 3 LT (Socket LGA1366) @ £47.99 inc VAT *** ***
The HEATKILLER® CPU Rev3.0 LT sets a new benchmark in cooling performance, build quality and user friendliness. The waterblock was designed with the newest CPU generations in mind. Central flow design, paired with a sophisticated nozzle plate and an extremely fine cooling geometry give the waterblock outstanding cooling performance while still having a very low flow resistance. The baseplate can geometrically adapt itself to the CPU. When used on a Quad Core CPU a distributor plate is included which directs the flow of coolant parallel to both DIEs of the CPU. The modular design allows easy opening of the HEATKILLER®, the change of the mounting plate to allow installation on another socket is done easily and quickly. Separately available mounting plates and replacement parts ensure, even after years, perfect operation and performance. The cooling geometry is made from electrolyte copper, the cover is made from high-quality POM. The mounting plate and design applications are made from stainless steel.
- Material: Electrolyte copper, POM, stainless steel
- Dimensions (block): 59 x 59 x 17,5mm
- Weight: approx. 150g
- Pressure tested: 5 bar
- Seal: EPDM 75 (max. 150°C)
- Thread size: G1/4" (DIN ISO 228-1)
- Compatible with Intel socket 1366
Only £47.99 inc VAT.
ORDER NOW
*** *** Heatkiller Full Cover GPU-X² Nvidia GTX 285 v2 Water Block - Copper @ £74.99 inc VAT *** ***
Its unique design allows the HEATKILLER® GPU-X² GTX285 V2 to boast unmatched performance. A cooling performance similar to current high-end CPU waterblocks, a modular VRM cooling module as well as materials of highest quality are the main features of the new GPU-X² series. Any components in contact with the flow of coolant are made from pure copper. The cooling structure for the GPU is finely machined to give even more performance than most CPU-waterblocks. The direct flow to the GPU cooling structure furthermore improves performance. To keep flow resistance as well as weight as low as possible all channels are very wide. The variable connection block can be revolved by 180° and therefore also allows connection from the bottom of the card. Optionally 4-way connector blocks or dual- as well as triple-SLI connector blocks are available.
- Material: Electrolyte copper, stainless steel, POM
- Dimensions (LxWxH): 108,0 x 118 x 10,5mm
- Weight: approx. 700g
- Connectors: G1/4" (DIN ISO 228 - 1)
- Compatible to: Nvidia Geforce GTX285 (PCB892)
Only £74.99 inc VAT.
ORDER NOW
*** *** Swiftech Epsilon GTX295 Single PCB Performance Water Block @ £126.49 inc VAT *** ***
The Epsilon™ water-block is a single slot, liquid cooling solution for nVidia® reference design (P658*) GeForce™ GTX295 graphics cards. This "full cover" waterblock cools the GPU, Voltage Regulators, I/O chip, memory modules, and other critical components.
The Epsilon™ water-block offers superior thermal performance at the GPU level thanks to an embedded thin-pin matrix located directly above the GPU area. Flow restriction is moderate by design in order to take into account multiple water-blocks in the same loop.
The base plate is made of chrome plated electrolytic copper, as opposed to commonly used nickel plating which is yellowish, and the top is machined in clear polycarbonate material. The advantage of polycarbonate over widely used acrylic is that it is virtually impervious to cracking.
High thermal conductivity grease pads are pre-applied in the memory and mosfet areas for user convenience. Short barb fittings are included for either 3/8" or 1/2" tubing and are compatible with quad SLI setups.
Only £126.49 inc VAT.
ORDER NOW
*** *** EK Gigabyte X58 Motherboard Blocks Kit - Acetal @ £96.99 inc VAT *** ***
This waterblock kit is specially designed for the Gigabyte X58. The waterblocks are made from electrolytic copper and high-quality Acetal. The cooling plate is extremely even and smoothened for an optimal heat transfer.
- Material: Copper, POM
- Weight: approx. 500g
Dimensions NB+SB:
- Copper baseplate: 162 x 58 x 5,5mm
- Acrylic top: 170 x 62 x 8mm
Dimensions VRM blocks:
- Copper baseplate: 123 x 26 x 12mm
- Acrylic top: 123 x 24,5 x 12mm
Only £96.99 inc VAT.
ORDER NOW
*** *** Swiftech Laing D5 Vario MCP655 12V DC Pump @ £69.99 inc VAT *** ***
In response to the overwhelming demand for a quieter MCP655, we are proud to introduce the new MCP655 pump, which features several key improvements: considerably reduced audible operating noise: the high pitch frequency of the MCP655 is now eliminated thanks to a new chipset controller, head and flow characteristics have slightly improved in the midrange,
a potentiometer allows you to adjust the pumps speed from 4800 rpm down to 1800 rpm. At 1800 rpm, the pump is virtually silent. This allows users to tune the pump performance/noise ratio to their particular preference.
- 50,000 hours MTBF (Mean Time Between Failure) equivalent to 5 years lifetime.
- Superior 12 Volts DC convenience: plugs into the computer power supply
- Superior real world performance versus any aquarium pump we have tested to this date.
- The high pressure capability of the MCP655 is particularly well adapted to high-flow systems using 1/2" ID tubing
- Pump speed can be adjusted to yield top performance or virtually silent operations
- Maximum discharge 317 GPH (1200 LPH)
- Compact design
- Quiet operations even at high speed thanks to new chipset controller
- ½" barb fittings
- No maintenance when used with de-mineralized water and additives
Only £69.99 inc VAT.
ORDER NOW
*** *** Aquacomputer Evo 1080 Radiator - No Fittings @ £114.99 inc VAT *** ***
Airplex evo 1080 is an optimized passive radiator with the option to install 9 x 120mm fans. The cooling performance of this radiator provides is extreme, suitable for the cooling of several PCs or server Clusters. To give the evo 1080 a unique look Aquacomputer have used the Aquaduct style grills.
- The connections are G1/4".
- Radiator and housings are black powder-coated.
- For the attachment of fans screws M3 x 35 are needed, these are not included.
- Dimensions 41.5 cm x 37 cm x 5.3 cm
Only £114.99 inc VAT.
ORDER NOW
*** *** Primochill Typhoon III Reservoir System (2 In 2 Out) @ £56.99 inc VAT *** ***
After three years of evolutionary development and building on the foundation of the original and extremely popular Typhoon, PrimoChill has taken a revolutionary leap forward with the introduction of the Typhoon III Reservoir System--proof positive the third time really is the charm. Designed by a pro case modder FOR case modders, Typhoon III is the perfect marriage of performance, reliability, ease of installation, and day-to-day usability with a huge helping of "modability" added to the mix. The heart of that performance is the most popular and reliable DC pump on the planet--the D5--which we mated to the easiest to install and easiest to fill and bleed reservoir ever made. It doesn't matter if you're just starting on your first modding adventure, or if the word hardcore bounces off of you like a cotton ball--Typhoon III is the best Pump and Reservoir choice you will ever make.
This version of the Typhoon III reservoir system features TWO outlet ports and TWO inlet ports allowing two discrete loops on the same reservoir, pump, and radiator without the use of additional manifolds or “Y’s” / “T’s” which can decrease efficiency in the loop/s. The pump housing features a full 360 degree deep-draw helix with an oversized (nearly double the stock D5) primary outlet that feeds an expansion chamber to decrease any pressure drop. The back of the housing is optimized for the dual bay upright mounting position so that water is spun up by a spiral structure that is humped (we buy it dinner first and ends in a very sharp edge at the inlet terminus which feeds water into the impeller at a decreased angle that lowers motor loading.
Only £56.99 inc VAT.
ORDER NOW
*** *** Primochill Typhoon III Reservoir System (4 In 4 Out) @ £56.99 inc VAT *** ***
ORDER NOW
CLICK HERE to view the full range.
I was wondering about that too... but may just stick with the supreme Im using, its doing a good enough job... but the heatkiller just looks so much nicer haha
If you have not seen a HK block in the flesh you will be blown away, best looking blocks I have seen yet by a fair way.
