I've got my Swiftech Storm block. A Silverprop Fusion HL is on the way. I'll be using 7/16" tubing with the warm water trick, with 1/2" ID barbs. This will be powered by an Eheim 1250 and the radiator will be some random 120.2 one I bought a long time ago.
Would the XSPC reservoir work well enough as a normal reservoir or is there a better non-bay one that I should use? I don't want to use a T-line as they look a bit messy.
