- 1 Sep 2020
- Liverpool
Can anyone give me a little advice on this issue im thinking that might crop up when I'm building this loop.
I'm wanting to build a water loop into my case and I was wondering about reservoirs and their heights. purely for aesthetic looks I was going to put an EK-Quantum Volume FLT 360 (no pump attached just the reservoir) on the back of my case and the power would be supplied by a Corsair Hydro X Series XD5 res/pump combo. The corsair res was going to be mounted onto the front fans and the EK Res just mounted to the back of the case next to the motherboard. What I was worried about though is if the EK res is higher than the top of the corsair res will the airgap that is in the corsair, once filled, be forced out and in to the EK res and the fluid that is in that EK res fill the corsair until there is zero air in that reservoir? Or will it just fill up and the air gap remain in the corsair as that’s the filling part, but it will be lower than the EK res. I have corsair 900d case and I have removed all the drive bays at the front of the case normally and that extra space created was why the EK res is going in to fill that space? Would the height difference in the two reservoirs make any problems once filled ?
Any help would he much appreciated.
Thanks
Adam
Thanks
Adam
