Hi Guys, iv been pulling my hair out for ages now trying to work out why my rig is running a little warm, it idles with all fans at maximum around 38-41 and loads at 47, although if i take the fans lower then it quickly heats up to above 50. has anyone got any idea what could be the issue or if one of the components is not suited to the rig.
its running 3 xigmatek crystal white led fans (1500rpm) on a black ice triple rad (the one with really high fpi tightly spaced fins) on the rear of the case and 2 noctua fans(ns-f12-1200rpm) on a swiftech double rad in the front. laing ddc 10w pump with xspc combines top and res, swiftech apogee gt cpu block, nvidia 470 aquacomputer aquagraFX full cover block.
running a phenom II x2 550 unlocked to a quad @ 3.4ghz, 1.45v, NB at stock 2000mhz, all voltages set as auto in bios, just the cpu voltage changed.
I was using a xspc delta v3 block but i got worse temps by a fair few degrees than the swiftech one, strange as that block by the reviews is pretty good, I just took it at the time that the small step on the base wasnt large enough to conduct the heat properly.
any ideas as its stumped me lol!
