Guys please help with my setup at the moment I am runing one 240mm rad to cool my 7970, its the rad im using is at the top of the case with a xspc 750 pump res combo. I want to change this setup up by adding another 240mm rad and changing pump for ddc 18watt with top reservoir and xspc ray storm cpu block.
Any ideas where to put the ddc pump plexitop res? Also the best way to install tubing.
Hi, top rad air flow exhaust[out], bottom rad air flow in, the other fans marked in green should be pulling air into the case. The bottom right hand side fan is that the PSU's fan? if so air flow out.
Ok, my extra tubing is coming tomorrow so I will give you advice a go, where would you install the pump? And will it make any difference how I route the tubing?
Ok, ive started my build and have found a problem if I setup as above the lower part of the case psu and 2 fans is expelling hot air into the path of the fan in the top part of the case, this fan is blowing in. Surely this would effect temps?
