Watercooling Setup V 2.0
17 Sep 2008
Hi guys,
Are there any pitfalls with this setup?
I'm trying to find a way to cool the CPU, NB and GPU in a small case with space restrictions. With your help I hope I can achieve this.
Many thanks
What watercooling parts do you have? For a loop that size you would probably need a 120.3 rad.
Also,by the looks of it your cooling your gpu first instead of the cpu-most people would recommend the cpu first-including me.
Ignore me-looked again and middle bit is nb-hard to see on my phone!
Like admiral said tho would try go rad to cpu but there would only be 1-2c difference in the temp in the loop anyway.
Thank you for the comments
Is the Black Ice GT Stealth 120 a good rad?
How about this?
Res/Rad 2X120 > pump > cpu > Rad 120 > NB > GPU > Res/Rad
Loop order makes very little difference, less than 1c iirc. The water temp will equalise around the loop - sounds against the principles of physics but it's true.
