- 19 Nov 2008
i am planning a custom G5 build and want it to be water cooled. i am currently on lower spec stuff but i want the cooling to be capable of effectively cooling a mid overclocked i7 and a high end gpu.
it is important that it is as quiet as possible.
i think its possible to fit a 2 240 rads into the case at worse a 240 and a 120 rad.
was wondering is it possible to make this type of system silent or near to it?
i think one of the rads will need to be slim and the other can be as thick as needed.
so what rads and more importantly what fans can be used?
i wont have space to do a push/pull on the rads either.
