Hey guys, have a few questionjs about an upcoming build, just wanted to check a few things.
The parts related to my question are listed below.
YOUR BASKET
1 x Asus X99-S - Intel Core i7 5820K Six Core CPU & Motherboard Bundle ***£30 Saving*** £505.98
2 x OcUK GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card £425.99 (£851.98)
1 x Hardware Labs Black ICE Radiator GT Xtreme 480 £84.98
2 x EK Water Blocks EK-FC980 GTX - Acetal £79.99 (£159.98)
1 x Hardware Labs Black ICE Radiator GT Xtreme 240 £56.99
1 x PrimoChill 240mm AGB CTR System Phase II - Clear £54.95
1 x Aqua Computer Cuplex Kryos PRO - Socket 2011 £49.99
1 x PrimoChill Revolver Compression Fitting Acrylic Tube 13/10mm Diamond 10-Pack - white £49.99
2 x EK Water Blocks EK-FC980 GTX Backplate - Black £22.99 (£45.98)
1 x Mayhems Pastel - UV White Coolant 1L £17.99
5 x PrimoChill 13/10mm Acrylic Tube 90cm - Clear £5.99 (£29.95)
Total : £1,923.76 (includes shipping : £12.50).
I have seen these bridge things about like these http://www.overclockers.co.uk/productlist.php?groupid=962&catid=1529&subid=2267 but don't know if I need one?? If I do, could somebody suggest one that's compatible with the cards/motherboard/compression fittings I have chosen?
Secondly. In my current build I have twin loops, one CPU one GPU, these are powered by two EK DCP 4.0 pumps. In the new build I will be dropping to a single loop. Is it advisable/necessary to still use two pumps with the loop setup and components I have?
Lastly, I assume those two rads will be enough to cool two 980's and the CPU I have chosen? I wont be doing push pull, will be one rad push and the other rad pull so airflow goes from left to right through the case (Corsair Obsidian 900D)
YOUR BASKET
