Watercooling Spec. BOSH!
17 Jan 2014
Hi All,
So I'm planning on Watercooling my new setup.
I've ordered the H440 Case which should be with me on the week of 10th Feb.
Setup:
NZXT H440 Case.
Intel Core i5-4670K
Gigabyte Z87-D3HP
MSI Radeon R9 280X Gaming Edition OC
Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz
Watercooling Setup:
YOUR BASKET
1 x XSPC D5 Photon 170 Reservoir/Pump Combo £129.95
1 x EK Water Blocks EK-FC7970/R9 280X - Nickel CSQ £82.99
1 x EK Water Blocks EK-Supremacy - Nickel £52.99
1 x EK CoolStream Radiator XT 360 (120.3) £48.98
2 x Mayhems X1 UV Red Premixed Watercooling Fluid 1L £7.99 (£15.98)
2 x Primochill Primoflex Advanced Tubing 13/10 - White £5.99 (£11.98)
8 x EK Water Blocks EK-CSQ Fitting 10/13mm G1/4 - Nickel £2.99 (£23.92)
Total : £376.38 (includes shipping : £8.00).
Any Suggestions?
Edit: just realise how full of excrement that advise was :D
Looks good to me mate :)
Ill be interested to see a white and red mix :)
Fans aimed for radiator use will work better. sp120's or Gt Scythes are usually the most recomended. also you might want to change the xt rad for a Ek PE rad, these are like the high end AX Xspc rads but cheap as the Xt's.
