Watercooling spec check and radiator question please :)
Permabanned
9 Oct 2006
Hey all, I feel pretty confident i'm close to being finalised for my Watercooling setup now, but I want to just run it over with you guys one more time incase theres any recommendations/changes you guys and girls have in mind :), also, I havent included a radiator as I was wondering what the main differences are between the 360 radiators, baring in mind i'll be cooling an an i5 3570k and a GTX 670 Windforce 3x in the future, so the cooling demand wont be too high I dont think, so I was wondering if the £80 radiators are worth it more than the say £40 maybe slightly thinner ones? :) but thank you for the help, it is hugely appreciated :)
YOUR BASKET
1 x Laing D5 Vario Pump -T12 VPP655 12V DC Pump £79.98
1 x XSPC D5 Dual Bay Reservoir £49.99
1 x XSPC RayStorm CPU WaterBlock (Intel) £49.98
1 x Mayhems X1 UV Blue Premixed Watercooling Fluid 1L £7.99
1 x XSPC HighFlex Hose 3/8" ID, 5/8" OD, 16/10mm, 2m, Clear £6.49
6 x EK PSC Compression Fitting 10mm 3/8" - G1/4 - Nickel £2.75 (16.5)
Total : £222.32 (includes shipping : £9.50).
All looks good :)
Things you may want to consider adding:
Tubing cutter
Bridging thingy for PSU
Rad wise, if you have the space, go for the thicker ones, they will knock a few degrees off temps.
The phobya g changer is one of the cheapest, but also one of the best
Ahh thank you :), i'm just a bit concerned about the res/pump combos possibly vibrating against the case and causing an annoying vibration, I may go for a standalone bay reservoir or a tube reservoir still yet, so many choices, so many decisions! :( haha :D
Personally I would always steer clear of res/pump combos. If you are bothered about noise nothing will be as quiet as a pump which is completely decoupled from the case. Mine is suspended by a short section of tube below a tube rez. No part of it touches the case and it is completely inaudible.
^ I would go along with this. The alternative is rather then use a piece of tube get a male to male fitting to secure the res to the pump. Something like this.
Yeh i've decided to go for the D5 with the EK top and the 250 advanced tube reservoir, I have a HAF-X so plenty of room to mount both, and for noise/performance it sounds like the best way to go, so I think that's what i'm gonna go with, thank you for the help though guys, it's helped a lot :)
