One freely admits that I'm not the biggest expert but:
-Whats case is this going into? Some cases (eg 650D) have issues with thicker rads
-Whats fans you using?
-Why have black fluid with black tubing. Would clear tubing not be the way forward?
-Gonna need more than 4 fittings! (plus they're outta stock). Need 2 for the cpu block, 2 for the rad, 2 for res and 2 for pump. 2 each cos its inlet and outlet. Unless I'm mistaken, if so everybody please correct me, thats £3.50 EACH!!! And you require 8 of them...
Maybe consider a fan controller. Fluid use de-ionised/distilled water from Halfords. Your choice mind but can't see the point having black fluid AND black tubes.
Any further critiques....
Thanks for that. Its going into a Corsair 800d. Was going to use black fluid so that it shows up in the reservoir but maybe clear tubing and black fluid is the way.
So basically i will need 8 of those compression fittings and a fan controller and i'm done?
Oops apologies - FAIL!
In which case what would fit? Both tubing and fittings said 3/8" ID (inner diameter).
Worst thing with custom watercooling is figuring out what fittings are correct IMO.
