Hey everyone!
Could you please check this spec for me and ensure that i have correct fitting etc or perhaps advise on any changes you might advise on?
I have a dual rad i will be re-using so this setup will have 2 dual rads in the loop.
YOUR BASKET
1 x OcUK Tech Lab - XSPC D5 Vario Pump & EK-D5 X-RES 140 CSQ Value Combo £114.98
1 x EK Water Blocks EK-FC980 GTX - Nickel £89.99
1 x EK Water Blocks EK-Coolstream RAD XTC 280 £59.99
1 x XSPC RayStorm CPU WaterBlock (Intel) £49.99
2 x Monsoon 16/11mm (ID 7/16 OD 5/8) Free Center Compression Fitting Six Pack - Orange £24.95 (£49.90)
2 x Monsoon 16/10mm (OD 5/8) Rotary 90° - Orange £8.69 (£17.38)
4 x Monsoon 16/10mm (OD 5/8) Rotary 45° - Orange £8.69 (£34.76)
1 x Mayhems XT-1 150ml UV Blue Coolant £6.98
3 x XSPC 7/16" ID (16/11mm) High Flex Hose - Clear (1m Length) £2.99 (£8.97)
1 x XSPC PSU Bridging Connector (24 Pin) £1.99
Total : £444.52 (includes shipping : £8.00).
Any help is appreciated as i have only done one setup before and that was years ago.
Much love!
YOUR BASKET
Much love!
