12 Jul 2006 at 22:20 #1 footman footman Soldato Joined 21 Oct 2002 Posts 4,320 My newly installed Swiftech apex kit mades the odd gurgling and "bumping" noises. Otherwise temps are great. What can this mean?
12 Jul 2006 at 22:23 #2 turbotoaster turbotoaster Associate Joined 29 Dec 2005 Posts 1,196 could be air in the pipes
12 Jul 2006 at 22:24 #3 ted34 ted34 Associate Joined 5 Jul 2005 Posts 1,734 Location Edinburgh Its air in the pump - knock it abit and try and move the air to the bleed hole
12 Jul 2006 at 22:28 #4 footman footman Soldato OP Joined 21 Oct 2002 Posts 4,320 ted34 said: Its air in the pump - knock it abit and try and move the air to the bleed hole Click to expand... do you mean tap it lightly with small hammer?
12 Jul 2006 at 23:38 #5 Carbine Carbine Associate Joined 15 Feb 2006 Posts 136 Location Worcester, West Mids footman said: do you mean tap it lightly with small hammer? Click to expand... haha no... shake the pump with your hand.. tilt the case etc
