Watercooling temp differences
10 Jan 2004
Hi all,
I have just installed another card into my PC that is watercooled. It is the same card and the same waterblocks and is in the same loop.
Three cards run under load at 55 degrees and then the new card I put in runs at 45 degrees. Even idle has a delta of 3-4 degrees.
I find it hard to believe that I messed up the block install on three cards or the paste has not been applied correctly etc. but I suppose it could be?
Any ideas?
