- 1 Oct 2015
Hi,
I had been using the XSPC Raystorm rs240 kit for past two years and decided to add a GPU block and 2 additional 120 radiators to the loop but i'm getting high gpu temps with my new setup. I've listed my setup below and the temps i'm getting, please advise me on troubleshooting this.
CPU : i5 2500k at 1.35V at 4.8GHz
GPU: MSI 970 4G Gaming overclocked
Pump/Res : XSPC D5 Vario Res/Pump Combo
CPU Block: XSPC Raystorm
GPU Block: EKWB 970 TF5
240mm Radiator: XSPC RS240
2 x 120mm Radiators : Alphacool NexXxoS ST30
Fans: Corsair SP120 Quiet Pull
Tubing: Roughly 2 metres of 19/13mm tubing
Setup as follows: Pump/Res > 240 Rad (Top of case) > CPU > 120 Rad (Rear of case) > GPU > 120 Rad (Bottom of case) > Pump/Res
Idle Temps:
CPU 30 degrees
GPU 27 degrees
Load Temps:
CPU 60 degrees
GPU 75 degrees
Any thoughts, are my temperatures normal for my setup or should i redo the loop and re-seat the GPU block?
Thanks
Idle Temps:
CPU 30 degrees
GPU 27 degrees
Load Temps:
CPU 60 degrees
GPU 75 degrees
Thanks
