Watercooling tip please? :D
4 Jun 2012
So I want to water cool my pc.. :) 1st time watercooling so I dont no much about it.
So I've been looking at: XSPC Rasa 750 RS240 WaterCooling Kit
Watching/reading reviews etc..
People say the tubing isn't the best quality and kinks easy..
So is the tubing fine to use for a first water cooling build?
No probs with the tubing at all. Though I would say depending on your case size/ gpu being cooled 2 meters might not quite fit. I have used just under 3 meters in my shinobi with the cpu, gpu and two rads. You ALWAYS end up cutting more than you mean to.
I've only ever used XSPC tubing and in both times, i haven't seen any reason to buy a different brand tbh, it's great tubing for a great price.
If you would bother to read the rules (which you should do because the mods here will come down on you like a tonne of bricks otherwise) you will understand that this forum is provided by the retailer Ocuk, Ergo it's against the rules to mention competitors ( IE companies that share a similar product base to what is sold here)
Haha ok, I get it. Um cant you PM me or something?
As OCuk doesn't sell the one I want. :( Or I would buy from OCuk
Nope, the forum don't feature a PM system.
concerning the one you want? which one? what? if your talking about tubing, then what size fittings are you using? also compression fittings? or Barbs?
