- 5 Dec 2014
I'm due to get a full refund on a 1080 Ti from Amazon and have decided to go down the water cooling route but I'm unsure which 2080 to buy.
What is the criteria for choosing a good card for water cooling?
I've been looking at perhaps a reference based card for water block compatibility. Some are "binned" with the 2080 Turing architecture and have higher stock clocks. Are cheaper blower cards an OC "risk" or will they clock fine on water?
There are a couple of cards that come with blocks already fitted. I'd probably prefer to have the Air Cooled option, but are pre-blocked cards going to give a better OC? Do specific water blocks perform better than others? Liquid metal on a GPU might make a difference too?
I'd like some noob guidance please. My last card lasted just over a year, with very, very light use and I think it might be due to running 3x 144hz monitors and a 4k TV. Water cooling must be the answer, but I don't have any experience in it.
... Clearly never tired it yourself?, being able to run your system at half the temps of air cooling with absolutely silent operation! Doesn't sound pointless to me! Plus the massive extra thermal headroom for overclocking!
