Waterfox/Firefox Users
20 Nov 2009
Hi Guys
I have been using Waterfox as the main browser on my PC now for quite a while but could never figure out how to get rid of the little status pop up that appears when a page is loading.
Have tried messing about with the Toolbar Layout but can't seem to get rid of it. Anyone know? Here's what I'm referring to by the way...
You could install this addon and have a look through the various options - bit of a sledgehammer to crack a nut, but I think it should do what you want.
Alternatively, there's a snippet of code you can add to userChrome.css - I can't be ***** to google for it right now, but it shouldn't be too difficult to find. :)
i wouldn't want to get rid of that. you always want to see the real URL a hyperlink points to when you hover your mouse over it.
Fair point guys. Will leave as it is then I think :)
If the popup annoys you but you still want to see the link URL on mouseover, the addon I mentioned will let you alternatively display it in the status bar or the location bar.
It's got quite a few other features also - mostly of a cosmetic nature, but it might be worth checking out.
I can't understand how the popup toast can be annoying in any way at all?
I'm assuming your input was creatively autocompleted by some kind of AI, unless FF has abilities I haven't yet discovered. :D
I remember the popup did get on my wick a bit when it first appeared (v4 or thereabouts?), but I got used to it pretty quickly and it hasn't really bothered me since.
Toast? It's a toast like notification on action hover, that's what it's called :p
