Right, here's a basic proposal.
I haven't bothered with specific fans/fittings/tubing etc yet as the rest needs to be finalized.
You could use an appropriate EK/Heatkiller bridge for the multicard setups if you wanted.
I went with the quad 180mm fan option for simplicity and possibly less noise. You'd want 4 silverstone 180mm fans for each rad and they're around £20-25 a pop, so perhaps 120's may be a better option?
The EK XT 360 rad in the 500R was picked for it's combination of size, price and fpi which would let you get away with lower rpm fans than an EK PE360 for example.
You will need to modify your case to fit it. See my build log for more info
Obviously, you'll have to shop elsewhere for a lot of this stuff.
Board 1
290
290
290
EK 290(X) blocks
Phobya Xtreme Nova 1080
Phobya Nova 1080 Radiator Feet
Phobya Nova Fan Grill 4 x 180mm Black
EK D5 X-Res 140 pump/res combo (mounted to rad)
Pulse Modding Reservoir / Pump Mounting Bracket
EK UNI Holder D5 for Laing D5 Pump Mounting
QDC's
Board 2
290
290
280
Watercool Heatkiller x3 blocks (in/outs should line up)
QDC's
Board 3 (500R)
7990
Aquacomputer block
EK XT360
Whatever pump res combo you like, except a bay mounted one
