Waterproof backpack
29 May 2005
Hertfordshire
Looking for backpack I can carry on a plane for travel that waterproof with enough room to fit my Canon camera and Go Pro any ideas?
any backpack, waterproof ziplock bags, problem solved.
or instead of ziplock bag you can get pouches for swimming that tie to your wrist/arm you put your clothes in so some ***** doesnt steal your clothes from the side of the river. probably easily big enough for a camera and go pro and 100% waterproof since they are supposed to keep your clothes dry
I think most hiking back packs these days are going to have a h20 slit in them for the pipe to a waterpouch so won't be completely waterproof
I usually use a regular backpack with reasonable water resistance and stick anything critical into a dry sack or two (usually have like a 10-20L one for clothing and 3-5L for electronics).
Most Osprey packs come with a water resistance cover, I've never tried it mind as I normally just carry water/tools.
I have an overboard roll top bag for cycling to work. Never had a drop inside. Decent size and not too badly priced.
Depends how wet you intend to get and how much you want to spend. For example, my requirements are either white water or sea kayaking so I'd only go with Watershed (£80 and up), or, a random backpack plus drybags within drybags. These are the only two options I'd trust but what works for you may be different
