Waterproof over-trousers fit
14 Dec 2005
Looking for a pair of tight(ish) fitting over-trousers, or a jacket/trousers set for cycling, 2 mile journey mainly on the flat so don’t need anything fancy...
Got these in a large and medium to try, the size large jacket is a little bit baggy but not too bad, the trousers in both sizes are far too baggy for my liking tho
Regatta Unisex Stormbreak Waterproof Rainsuit | Taped Seams https://www.amazon.co.uk/dp/B01JGIXLNE/ref=cm_sw_r_cp_tai_sOGPDb8RKMQJA
Not looking to spend a lot...any suggestions?
Cheers
What are you riding and hows your position? What clothing are you wearing for riding/commuting and what's your budget?
I party ask because the vast majority of overtrousers/waterproofs are made for standing/walking/hiking upright type posistions and not for the general cycling position. That's one of the reasons why buying cycling specific kit can help massively, but again that depends on how you're riding and what your budget is as it's generally twice the price or more...
I'm always in cycling kit, even with my 2.4 mile ~8 minute commute.
I own various packables but for real rain riding you're best with a proper jacket. For jackets I'd always buy cycling specific. I own/have owned Altura Nevis, DHB Commuter, DHB EQ2.5 and now a Proviz 360. Dropped tails, vents, raised collars, multiple layers and fasteners around wrists make a huge difference to wet riding and are worth paying extra for. As you're generally spending more for cycling specific you then need something that's multi-season to justify it a little so I've found it is generally best just an outside layer to keep the elements out, then you can layer under it depending on temperatures. You also need some breath-ability / various vent options. Especially commuting as you generally have 2 rides in different conditions most days.
After using general 'cheap' overtrousers and either wrecking them (ripped/caught in chain etc), or getting fed up of the flapping, I previously got DHB Mono Overtrousers. The fit was better, being able to tape in the legs was great although the velcro not that well positioned. Waistband wasn't great, I ended up using suspenders with them to hold them up. The fit on my thighs was a little too tight, they eventually tore/came apart on the inner leg. I've still worn them for the really heavy rain 4-5 times since but last time more of the leg came away so it was time to replace them. I ordered some Altura Nevis III after originally wanting the 'Pro' but being unable to justify the cost, then looked at the Cyclone and Nightvision. But when it came to ordering some the best place to buy them was the Altura website where the Nevis III where the only ones in my size, but several sales on there at the moment so worth a look if £30 is within your budget...
I've not worn them yet so can't comment (only arrived today). I wouldn't really spend more on waterproof overtrousers as I only generally wear them in the heavy rain. I own various leg/knee warmers with water protection (Castelli Imprevisto & Sportful NoRain) so for showers I don't bother with legs, only when there's heavy rain.
thanks for the replies :)
I'd already ordered the regatta packit trousers mentioned to see if there's any difference to the 'stormbreaker' ones I've already tried but if they don't work out I'll look in to the cycling specific ones mentioned. I did kinda think that any over-trousers might have the same issues (getting caught in chain/flapping about etc) just because of what they are but was just hoping there was some go-to brand for cycling.
It's just a bog standard mountain bike sticking to cycle paths/pavements...looking to get fit without boring myself to death so cycling the fairly short journey to work seems like the best idea atm :)
You could always use a reflective elastic strap or some kinda trouser clip if fouling on your crank is an issue.
Although I just wear mtb style shorts 95% of the time, you'll get wet but they don't retain water so they dry really quick too.
Over the past ~2.5 years of accumilating "race fit" cycle clothing/kit, I've mostly resisted wearing any of it to commute ~4.5 miles each way on my usually 29ered fatbike. Only exceptions are the Time ATAC pedals and old shoes since spring, plus I've worn a jersey once. I'm not a morning person, which makes getting in to work for 0630/0700 depending upon the day a challenge during the winter months, I rarely arrive at work with more than enough time than to quickly ditch my helmet/jacket/lights/shoes into my locker and put my work shoes on.
So for work, if it's raining, I simply wear a pair of Regatta waterproof trousers very similar to that link in OP with my PX Hydrosphere jacket. The trousers' breathability is not great.
Outside work, https://www.merlincycles.com/funkier-s-978w-winter-aqua-repellant-bib-tights-87077.html work well on the fatbike from around October to March, if it's raining and I actually decide or need to go out in the wet, often with a pair of MTB baggies over the top. Never been caught out in them during heavy rain, but they've been fine in lighter stuff and are far more breathable than the Regatta trousers.
