I am in the process of upgrading my computer.
I have the system built just waiting for a CPU, so I am leak testing at the moment but even after a couple of hours my Eheim waterpump still makes noise
There are almost no visible airbubbles going round so i'm stumped, could it be trapped ait in the pump?
Sometimes when I cut the power and put the plug back in the noise is less only to appear again later
Only thing I did different this time was add a UV reactive additive to the water, but surely that can't be the cause, can it?
but the pump is working fine, I can see the waterflow in my small res and the flow is fine.
