sitting here contemplating a new resevoir and was thinkin..
anyone rememebr the old wave tank type sideboard things that had oil and water mix and were illuminated.?
this type of thing
http://www.youtube.com/watch?v=QBQSMB_9vfs&feature=related
well i was thinking for a bit of fun make one as a pc resevoir as long as the motion is slow and the water intake and outlet are high enough above the oil water turbulance level, the oil to not suck the oil into the pump and the diference in specific gravity of the oil used is a lot diferent from the water they wont mix. and you could have a really nice external resevoir as a feature
sort of like this but not so naff lookin you could also have like a false tank so one half is separated from the other with a film membrane. so it would look like one tank but actually there would be no chance of the 2 fluids mixing
that would then give you a wider range of oils or fluids to be used in the bottom half of the tank ... so the effect could be greater with less risk of contamination to the water side....
what u reckon i may build one for a laf
this type of thing
