Hey guys
Maybe wrong place but I was wondering, is there a way to automatically turn an XBOX 360 off either when it's not in use or at a scheduled time?
I use my xbox 360 to play videos from my pc (media sharing from WMP over the network) but occasionally I forget to turn it off overnight, I have configured my PC to auto shut down after 2AM every day which is fine but I can't see any way to do something similar with the XBOX 360.
The only setting I did see on the XBOX was the switch off after 6 hours option, unfortunately you can't change the timeframe so it's either 6 hours or nothing!
Any ideas anyone?
If nothing can be done to switch off on the device itself or over the network then maybe there is some kind of plug adapter that can be configured to turn off at a certain time?
Regards,
Any ideas anyone?
Regards,
