WC newbie, need some help with a Antec Kuhler H20 620 and adding second fan
18 Oct 2002
Hi there guys,
I'm going to ocUK tomorrow to pick up an Antec Kuhler H20 620 water cooling system, and 2x Scythe Gentle Typhoon 120mm 1850 fans (to replace the one fan it comes with), but I have some quick questions...
The system comes with only 4 screws (which are used to attach the one fan to the case and radiator), does it come with extra screws to attached the second fan.
Next, How do I power the second fan, can it be connected to the pump, like the first fan?
Are teh Scythe Gentle Typhoon 1850 fans thicker or thinner than the stock fan and if so do I need to trim the screws down to avoid damaging the raidiator, and are they going to be suitable.
The system they will beused in will be a AMD Bulldozer 8120 FX-8 core 3.1 GHz system.
Thanks and thanks in advance for replies.
Thanks for the reply koooowweeee :)
If I use the 3 pin spliter, does it provide enough power to power both fans at full speed (if needed) or would it be pulling too much power?
Sorry for the stupid questions, but yeah... I'm dumb with WC... :P
