D5 is very good and adjustable, nut quite large so make sure you have room another good one is the laing DDC very good and compact, but u need the plexi top for 1/2" fittings
Try and get a 120.2, is larger so therefore better cooling, a heatercore should give even better results though and they can be had for £25 or cheaper if you get one from the scrapyard
