Hi guys, I am in the process of putting my rig under water, I was only planning on cooling my GPU and CPU, but I have decided to get the EK mobo blocks for my UD5 as well.
The pump I have atm is the Laing DDC Pro 10w, and I was wondering if someone could tell me whether or not it would be able to cope with my loop?
I will be using 2 rads, a triple and double, then I have my Heatkiller 3 CU, EK FC-GTX280 block, and the NB/SB and mosfet blocks on my mobo.
Hopefully someone here can tell me if I will be good to go, or whether I will need to purchase another pump or not.
Thanks in advance
Thanks in advance
