I'm at the end of my tether with this, it should be relatively straightforward to set up but it just doesn't want to work for me.
All of the configuration examples make it seem like childsplay to get working but it just doesn't seem to slot together!
Cisco ASA 5510 with Security Plus licence running 8.2(1)
Relevant stuff:
So it successfully registers with the Squid proxy...
Squid config is set up as:
iptables on the Squid box:
iptables -t nat -L -v shows hits to the redirect rule as expected and in line with the packet counter from the ASA.
I can tcpdump the GRE tunnel interface and see the redirected packets but tailing /var/log/squid3/access.log shows absolutely nothing at all. If I point my browser straight at the Squid box it works absolutely fine.
I am running kernel version 2.6.35 (which should work), iptables 1.4.4 (again should work!) and Squid 3.1.6 with netfilter support compiled in!
I have googled this into oblivion and I just can't see what is wrong!
Relevant stuff:
Code:
firewall transparent
access-list wccp_redirect extended deny ip host 10.33.0.17 any
access-list wccp_redirect extended permit tcp any any
wccp web-cache redirect-list wccp_redirect
wccp interface inside web-cache redirect in
Code:
wccpfw1(config)# sh wccp
Global WCCP information:
Router information:
Router Identifier: 10.33.0.16
Protocol Version: 2.0
Service Identifier: web-cache
Number of Cache Engines: 1
Number of routers: 1
Total Packets Redirected: 105
Redirect access-list: wccp_redirect
Total Connections Denied Redirect: 0
Total Packets Unassigned: 7
Group access-list: -none-
Total Messages Denied to Group: 0
Total Authentication failures: 0
Total Bypassed Packets Received: 0
Code:
http_port 3129 tproxy #also used intercept to no avail
wccp2_router 10.33.0.16
#All other options defaulted to use GRE
Code:
root@squidtest:/# iptables -t nat -L
Chain PREROUTING (policy ACCEPT)
target prot opt source destination
REDIRECT tcp -- anywhere anywhere tcp dpt:www redir ports 3129
Chain OUTPUT (policy ACCEPT)
Chain POSTROUTING (policy ACCEPT)
MASQUERADE all -- anywhere anywhere
Code:
root@squidtest:/# uname -r
2.6.35-22-generic
root@squidtest:/# iptables -V
iptables v1.4.4
root@squidtest:/# squid3 -v
Squid Cache: Version 3.1.6
configure options: '--build=i686-linux-gnu' '--prefix=/usr' '--includedir=${prefix}/include' '--mandir=${prefix}/share/man' '--infodir=${prefix}/share/info' '--sysconfdir=/etc' '--localstatedir=/var' '--libexecdir=${prefix}/lib/squid3' '--disable-maintainer-mode' '--disable-dependency-tracking' '--disable-silent-rules' '--srcdir=.' '--datadir=/usr/share/squid3' '--sysconfdir=/etc/squid3' '--mandir=/usr/share/man' '--with-cppunit-basedir=/usr' '--enable-inline' '--enable-async-io=8' '--enable-storeio=ufs,aufs,diskd' '--enable-removal-policies=lru,heap' '--enable-delay-pools' '--enable-cache-digests' '--enable-underscores' '--enable-icap-client' '--enable-follow-x-forwarded-for' '--enable-auth=basic,digest,ntlm,negotiate' '--enable-basic-auth-helpers=LDAP,MSNT,NCSA,PAM,SASL,SMB,YP,DB,POP3,getpwnam,squid_radius_auth,multi-domain-NTLM' '--enable-ntlm-auth-helpers=smb_lm,' '--enable-digest-auth-helpers=ldap,password' '--enable-negotiate-auth-helpers=squid_kerb_auth' '--enable-external-acl-helpers=ip_user,ldap_group,session,unix_group,wbinfo_group' '--enable-arp-acl' '--enable-esi' '--disable-translation' '--with-logdir=/var/log/squid3' '--with-pidfile=/var/run/squid3.pid' '--with-filedescriptors=65536' '--with-large-files' '--with-default-user=proxy' '--enable-linux-netfilter' 'build_alias=i686-linux-gnu' 'CFLAGS=-g -O2 -g -Wall -O2' 'LDFLAGS=-Wl,-Bsymbolic-functions' 'CPPFLAGS=' 'CXXFLAGS=-g -O2 -g -Wall -O2' --with-squid=/build/buildd/squid3-3.1.6
