WC'ing a X1900XT?
Suspended
17 Mar 2006
The stock fan is a bit noisy even with headphones (open) I can hear it, so any recommendations for watercooling kits for X1900XT? If I remove the videocard fan, how would the ATI video RAM and mosfets be cooled?
CPU water block would be useful also (939) Would a single 12cm radiator be suitable? (mount on the upper stacker exhaust, replace the stock Coolermaster low CFM/quiet fan with higher 70CFM Thermaltake fan
Northbridge and Southbridge are passive heatsinks but they don't need to WC them (don't get that hot)
I don't know about watercooling, but I would just get a Zalman VF900 and be done with it! Very quiet and great performance for £26.
p.s. I know what you did (to the X1900XT) last week :D
I've got a x1900xt-x on water.
I use a 120.1 to cool just the card, I wouldn't recommend putting the gpu and cpu on a 120.1. I cool mine with a DD Maze 4 LP and OCZ ramsinks (the ramsinks required a bit of modding to fit under the low profile version of the maze 4).
Temps are much better than the stock cooler; around 30c idle and 39c load with the core at max voltage (1.575v).
I can echo that just mine is an XT with an aquaxtreme MP-1 and zalman ramsinks :)
Tom
I'm just about to do the very same :D I'm running the swiftech MCW55 on mine with the Nvidia fittings
Rob
PaperAngel said:
Did i hear correctly somewhere that a X1900 with the stock cooler under load can get to 90 Degrees and above?
PA.
Yes very easily especially in shader intesive games like oblivion & fear
I run my XT-X under water. See sig. Works really well. Maze 4 is the way to go. 120.1 would struggle cooling the X1900 and a CPU.
