wd sata II AND scc- A QUESTION
2 May 2006
BUILDING A NEW SYSTEM, wondering if u can a nswere a quick question?
Intel Pentium D 930 (BX80553930) Dual Core 3.00GHz FSB 800
Cossair Value 2GB (2x1GB) PC5300 667MHz DDR2 Dual Channel Kit
Western Digital Caviar Special Edition 160GB 1600JS SATA-II 8MB Cache-
Western Digital Secure Connect Serial ATA Cable (CB-000-WD)
Western Digital Caviar Special Editions 120 GB PATA drive
Gigabyte 8I945P-G
M Audio audiophile 96/24 pci sound card
Zalman CNPS9500-AT Aero Flower (Socket 775)
Tagan TG420-U01 420W ATX2.0 Silent PSU (CA-002-TG)
Only using one sata and pata for back up- should the sata jumper be set to scc?
thanks in advance
I'm going to ask a dumb question here but what is scc? Are you talking about cable select or something? If so you don't have to set any jumpers on most SATA drives as there is only one device per chain, if you are talking about SATAII connectivity then you might need to set a jumper on the back to enable SATAII but it will work fine as a SATA drive anyway.
