wd320gb sata2 vista 32bit oem problem
17 Jul 2005
Hi,
Got the wd hard disk and vista at the same time.Vista will not detect the hard drive at all.Not sure why but if anyone could help I would be grateful.
My memory is 2x512 the motherboard is msi 865pe neo 2 and an old p4 cpu.
I will post this in both the os and the hard drives forums if that is ok.Thanks for any help.
Kind regards,
mconnaola
you need to put the sats2 drivers on a floppy disk
on the start of the windows install press F6 and then when prompted
select the driver device on the floppy. then after it goes back the the
same screen press Enter and finish the windows install
you sata2 drivers can be found on your drivers CD or you can
download them here..
http://www.msi.com.tw/program/search/ser/SerConDownRes.php?keyword=865pe&kind=
if you need any more help lets us know.
note not all Company's have Vista drivers out atm tho so you might have to wait
