WDS and Recovery Partitions?
12 Jul 2010
Telford, Shropshire
Hi folks,
Been tasked with looking into using WDS for our images etc, and I have a quick question. Is it possible to create a Recovery Partition through WDS at all?
Sorry if this is a silly question, still learning the ropes with WDS in general :)
Thanks for any help
You can create an answer file for use with WDS which will create any partitions you like. I'm a bit confused why you would create a recovery partition though? The purpose of WDS is to quickly deploy a system image, so why would you also have a recovery partition?
Thanks for the reply.
Its mainly for the benifit of our customer, we want to have a recovery partition so if any problems our customers can quickly restore, like dell/hp laptos etc.
