WDS + Win 7 Sysprep with answerfile
18 Oct 2002
Cambridge
I've setup WDS on a new 2008 R2 server for one of my clients to facilitate the roll out of lots of new Win 7 x64 laptops. Before uploading the image i sysprep'd it after configuring it. I have attached an answer file created using WSIM within WDS but get the following errors during the install:
Windows could not parse or process the unattend answer file for pass [Specialize]. The settings specified in the answer file cannot be applied. The error was detected while processing the settings for component [Microsoft-Windows-Shell-Setup].
I click ok and it restarts and then says preparing computer for first use when the following error appears:
The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed.
Clicking ok just restarts the machine and returns the same error again.
If i remove the answer file from WDS the laptop installs fine albeit with me having to enter stuff during the first boot. I can't see anything odd in the area that it fails in and it validates fine in WSIM. Here's the answer file:
Code:
<?xml version="1.0" encoding="utf-8"?>
<unattend xmlns="urn:schemas-microsoft-com:unattend">
    <settings pass="specialize">
        <component name="Microsoft-Windows-International-Core" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            <InputLocale>0809:00000809</InputLocale>
            <SystemLocale>en-GB</SystemLocale>
            <UILanguage>en-GB</UILanguage>
            <UserLocale>en-GB</UserLocale>
            <UILanguageFallback>en-GB</UILanguageFallback>
        </component>
        <component name="Microsoft-Windows-Deployment" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            <RunSynchronous>
                <RunSynchronousCommand wcm:action="add">
                    <Order>1</Order>
                    <Path>net user administrator /active:yes</Path>
                </RunSynchronousCommand>
            </RunSynchronous>
        </component>
        <component name="Microsoft-Windows-Shell-Setup" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            <RegisteredOrganization>######</RegisteredOrganization>
            <RegisteredOwner>Administrator</RegisteredOwner>
            <ProductKey></ProductKey>
            <ComputerName>*</ComputerName>
            <OEMInformation>
                <Logo></Logo>
                <SupportURL>#####</SupportURL>
                <SupportPhone######</SupportPhone>
                <SupportHours>08:00 - 18:00 GMT</SupportHours>
                <Manufacturer>#####</Manufacturer>
            </OEMInformation>
            <ShowWindowsLive>false</ShowWindowsLive>
            <TimeZone></TimeZone>
        </component>
        <component name="Microsoft-Windows-RemoteAssistance-Exe" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            <fAllowFullControl>false</fAllowFullControl>
            <fAllowToGetHelp>false</fAllowToGetHelp>
        </component>
        <component name="Microsoft-Windows-IE-InternetExplorer" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            <BlockPopups>yes</BlockPopups>
            <CompanyName>####</CompanyName>
            <DisableAccelerators>true</DisableAccelerators>
            <DisableFirstRunWizard>true</DisableFirstRunWizard>
            <DisableOOBAccelerators>true</DisableOOBAccelerators>
            <EnableLinksBar>false</EnableLinksBar>
            <LockToolbars>true</LockToolbars>
            <MSCompatibilityMode>true</MSCompatibilityMode>
            <SuggestedSitesEnabled>false</SuggestedSitesEnabled>
            <Window_Title_CN>M5N</Window_Title_CN>
            <GroupTabs>false</GroupTabs>
            <Home_Page>######</Home_Page>
        </component>
        <component name="Networking-MPSSVC-Svc" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            <DomainProfile_EnableFirewall>false</DomainProfile_EnableFirewall>
            <PublicProfile_EnableFirewall>false</PublicProfile_EnableFirewall>
            <PrivateProfile_EnableFirewall>false</PrivateProfile_EnableFirewall>
        </component>
        <component name="Security-Malware-Windows-Defender" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            <DisableAntiSpyware>true</DisableAntiSpyware>
        </component>
        <component name="Microsoft-Windows-powercpl" processorArchitecture="amd64" publicKeyToken="31bf3856ad364e35" language="neutral" versionScope="nonSxS" xmlns:wcm="http://schemas.microsoft.com/WMIConfig/2002/State" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            <PreferredPlan>8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c</PreferredPlan>
        </component>
    </settings>
    <settings pass="oobeSystem">
        </component>
            <OOBE>
                <HideEULAPage>true</HideEULAPage>
                <NetworkLocation>Other</NetworkLocation>
                <ProtectYourPC>2</ProtectYourPC>
                <HideWirelessSetupInOOBE>true</HideWirelessSetupInOOBE>
            </OOBE>
            <UserAccounts>
                <AdministratorPassword>
                    <Value>egAxAG4AdwA0AHYAMwBBAGQAbQBpAG4AaQBzAHQAcgBhAHQAbwByAFAAYQBzAHMAdwBvAHIAZAA=</Value>
                    <PlainText>false</PlainText>
                </AdministratorPassword>
                <LocalAccounts>
                    <LocalAccount wcm:action="add">
                        <Password>
                            <Value>egAxAG4AdwA0AHYAMwBQAGEAcwBzAHcAbwByAGQA</Value>
                        </Password>
                        <Description>Administrator</Description>
                        <DisplayName>Administrator</DisplayName>
                        <Group>Administrators</Group>
                        <Name>Administrator</Name>
                    </LocalAccount>
                </LocalAccounts>
            </UserAccounts>
            <RegisteredOrganization>#####</RegisteredOrganization>
            <TimeZone>GMT Standard Time</TimeZone>
            <FirstLogonCommands>
                <SynchronousCommand wcm:action="add">
                    <Order>1</Order>
                    <CommandLine>%SystemRoot%\System32\reg.exe LOAD "HKU\Test" "%USERPROFILE%\..\Default\NTUSER.DAT"</CommandLine>
                    <Description>Load Default profile into hive</Description>
                </SynchronousCommand>
                    <Order>2</Order>
                    <CommandLine>%SystemRoot%\System32\reg.exe ADD HKU\Test\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced /v HideFileExt /t REG_DWORD /d 0 /f</CommandLine>
                    <Description>Show file extensions in Explorer</Description>
                    <Order>3</Order>
                    <CommandLine>%SystemRoot%\System32\reg.exe ADD HKU\Test\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced /v Start_ShowRun /t REG_DWORD /d 1 /f</CommandLine>
                    <Description>Show Run command in Start Menu</Description>
                    <Order>4</Order>
                    <Description>Start Navigation Sound</Description>
                    <CommandLine>%SystemRoot%\System32\reg.exe ADD HKU\Test\AppEvents\Schemes\Apps\Explorer\Navigating\.Current /v &quot;&quot; /t REG_SZ /d &quot;&quot; /f</CommandLine>
                    <Order>5</Order>
                    <CommandLine>%SystemRoot%\System32\reg.exe UNLOAD "HKU\Test"</CommandLine>
                    <Description>Close the Default profile hive</Description>
                    <Order>6</Order>
                    <CommandLine>%SystemRoot%\System32\reg.exe ADD HKLM\SYSTEM\ControlSet001\Control\CrashControl /v  AutoReboot /t REG_DWORD /d 0 /f</CommandLine>
                    <Description>Turn off Auto Restart</Description>
                    <Order>7</Order>
                    <Description>Turn off remote assistance</Description>
                    <CommandLine>%SystemRoot%\System32\reg.exe ADD HKLM\SYSTEM\ControlSet001\Control\Remote Assistance /v fAllowToGetHelp /t REG_DWORD /d 0 /f</CommandLine>
            </FirstLogonCommands>
        </component>
    </settings>
    <cpi:offlineImage cpi:source="catalog://cwg1port/d/sources/install_windows 7 professional.clg" xmlns:cpi="urn:schemas-microsoft-com:cpi" />
</unattend>
I've #'d out any private info. Anyone have any ideas? I'm getting quite confused with this!
