- 19 Feb 2006
- West Mids
I have never had much luck with oc'ing but these numbers seem pretty pathetic to be failing this low, so im assuming I have done something wrong.
It's a little blury so i'll go over the numbers.
HTT x4 = 920mhz
Memory Clock @ 266 = 180mhz
CPU Voltage @ 1.40 (despite cpuz saying otherwise)
So core speed a little over 2.5ghz
It fails both Prime and Orthus within seconds, I know the obvious thing to do would be to drop back the FSB some but surely FSB 230 can't be the top end of the dial
I have tried upping the voltage as high as 1.475 but still no luck, also going to even 235 on the FSB = locking up before windows boots.
The board is a Abit 3rd Eye.
Can anyone see anything glaringly obviously wrong.
HTT x4 = 920mhz
i'm sure you're well aware, but, just keep an eye on the temps
