web browser benchmark?
13 Dec 2003
UK
does anyone know that website which benchmarks web browser speeds
ive had a look around but cant remember what its called
thanks
ah ok thats one i was looking for
i'll give the others a try too thanks
acid 3 gives 71/100 and says linktest failed
is there a problem :confused:, im sure when i tried it last i was getting in the low 90s
ive tried both the 3.1 and 3.5 beta (im using windows 7 64)
i just cleared some stuff, run ccleaner, cleared caches and now its showing as 93/100 but still linktest failed
it does all feel nippy now
Iron browser ? i never heard of it
I dont think the Acid tests are meant to be a measure of performance. They are more of the rendering engines ability to display CSS and other web standards correctly.
