Web pages/downloads stop, but other connections not affected!
DiG
DiG
16 Mar 2004
Hi, got this problem
When I'm on the internet (via wireless) a web page or download will just stop, and won't start again unless I press stop then refresh. The weird bit is no other connections are affected, I can download stuff and open new pages fine!
Any ideas?
Thanks
What virus scanner?
Intermittent timeouts and failed page loads can be caused by web scanners bundled with certain anti-virus packages that process all HTTP traffic, such as Kaspersky "Web Anti-Virus" and Avast! "Web Shield". In such cases,
* In the Kaspersky "Web Anti-Virus" component, you can uncheck the "Scan HTTP traffic" option. [13]
* In the Avast! "Web Shield" component, you can disable the "scan all files" web protection option and enable scanning only for downloadable executable files in web traffic [14].
Also try using OpenDNS.com's servers for a day and see if that makes any difference - full instructions at their site.
