Webcam and motion detection software,
19 Jun 2004
On the Amiga500
Hi,
a friend of mine keeps having her car vandalised at night and I suggested she gets CCTV of some kind. The best budget way to do this I was thinking was webcam and motion detection software on her PC from the top floor window?
Could you spec me a decent camera to use at night and a software that automatically records any motion detected?
Many thanks
sod the motion sensor, just record everything from a pre-determined angle. then if nothing was done delete it and re-record again the next night until you catch the vandal
No, plug and play doesn't mean it plugs and plays on a pc - it relates to any type of connection.
It looks like it outputs RCA so you'd just need a cheap capture card (usb or pci available) to record it (google 'rca capture card').
If you're going to be using motion detection software, make sure the capture device is supported - a lot of usb capture devices such as dazzle stuff will only work with their capture software.
I got a Logitech HD Sphere. It works well untill very dark. But you will need 3rd party software for motion detection. Your best bet is a cheap cctv kit black and white good for low light.
