Hi,
I play a lot of Arma 2 and I heard about this software called facetracknoir which is like track ir but uses a webcam instead of expensive tracking equipment.
Now I have tried this software with my basic no frills pcline webcam and...it works, sort of. Its sluggish in tracking my movement and its like playing through the eyes of a drunk person. Not good.
So I am now looking at getting a better webcam, the thought process being better webcam = less sluggish tracking = arma 2 will be better to play.
Now I don't have a budget but I thought £50 would be a reasonable amount to spend to get something good enough for this purpose.
Which webcam should I buy, perhaps if you have experience of using it with facetracknoir and it works well then could you share this information with me.
If £50 is too little to get something that will be up to the job, then spec me the most affordable webcam that will be suitable.
Thanks
Thanks
